Help! Replacing rod bearings...
GTR-33
Hey, I'm replacing the rod bearings in a Redtop SR20DET and I need the torque specs... If anyone could help out ASAP it would be great.
PS the SR20DE has the same crank...
GodzillaFan
apply oil to bearing and bolt threads.install all caps,tighten all nuts to 10-12 ft/lbthen, tighten all nuts 60-65° (or 28-33ft/lb)
GodzillaFan
if your using new crankshaft,. match bearing grades to grades printed on the crank.
GTR-33
Awesome, thanks man! Thats all I needed.:ylsuper :ylsuper :ylsuper
Nismo_Freak
Car: 89 Nissan 240SX
GodzillaFan wrote:if your using new crankshaft,. match bearing grades to grades printed on the crank.
Make sure it wasn't reground though
migsk8
Car: 240sx
i know this is mad old, but where is it printed on the crank ?
