b13dw »
https://forums.nicoclub.com/b13dw-u71000.html
Mon Apr 02, 2012 8:52 pm
My first post, but a frequent to the forums! You guys have helped me replace my MAF, IAC, idle relearn, clean my throttle plate, and much more in my 2001 I30t.
I am looking to replace my Heated Oxygen Sensor 1, Bank 2 due to a P0153 code. I purchased a new Bosch sensor as well as an O2 sensor socket (22mm) and was all set to go this afternoon when I got stuck. Of all things, the harness connector between the O2 sensor and the wiring back to the ECM that sits right in front, behind the radiator, won't detach.
Can someone help me with how these two connectors disconnect from each other? The wiring harness connector that plugs into the O2 sensor seems to have some kind of tension spring release mechanism. But whether i try to push down on that and pull the connectors apart, or wiggle a flathead in there, I cant get them apart.
I'm assuming I'm just missing something obvious because all of the posts here regarding O2 sensor replacement just seem to gloss over this. Any help is appreciated!
