ghostinator (fl) »
https://forums.nicoclub.com/ghostinator-fl-u71767.html
Tue Jul 24, 2007 5:08 pm
What year model do you have? 90-92 Non turbos and 90-94(i think) turbos have crappy injector connectors. Check them for corrosion first, clean them up put some dialetric grease on them and it should work alot better. happened to me when i bought my z. To replace them you would have to do a plenum pull, or the dremel method. Try cleaning the corrision off first and if that doesn't work i'll get you some links to how to replace injectors.
