help replacing fuel pump on 90 2+2
TYL3R hez
Car: 93 z32 2+2
92 z32 twin turbo drift car
90 z32 2+2
^^*All gone but not forgotten*
03 Is300 5-speed
first off my fuel pump finally bit the dust today...on my effing birthday :/
I kept hearing buzzing noises after I installed my fujisubo catback, and it would hard start on really cold days, I replaced my coolant temp sensor and still nothing.
so it only leaves me to belive its the fuel pump!!
I've seen plenty of how to's on tt's and 2+0's.
But does this method also apply to the 2+2?
*removing the rear interior peices to have access from the gas tank above the car*
Or do I need to drop the fuel tank and do it that way?
:) thanks in advance everyone!!! :dblthumb:
chaunceysj
Car: 1991 300zx 2+2 (tt swap coming soon)
2004 prius
1999 safari
2009 aura
1972 beetle (still waiting)
its super easy on the 2+2. pull the fuel pump relay and depressurize the fuel system.remove your spare tire. its in the trunk just pull out the carpet and fiberboard cover and pull the spare out. under the spare is a square patch held in by 4 screws. unscrew this and you will see the top of the fuel pump cover. remove the bolts holding this on and remove the hoses before you pull the assembly out. then voila your fuel pump is out. replace it and put it all back together.
