As stated in the title I replaced the two items with used parts purchased from a member here. Now I get no pump noise at all and no start. I ran the car as a test after just replacing the FPCU and it worked. I replaced the pump and now it's dead. I've replaced the fuse, plugged both parts in, but get nothing. I hooked the old pump back up (and grounded it) and it didn't hum either. Any ideas at all? I need to get the car back together quickly as it is my daily driver.
Thanks,
Jman
Update:OK, I jumpered the FPCU again and it worked. I then plugged it back in and it started to operate normally. I took it for a test drive and it worked great. A little later and the car would start, but would sputter and die. Any ideas?
Modified by Jmanolinsky at 12:41 PM 7/31/2008
