help removing stock shifter
wingedmark
Car: 2007 nissan sentra 2.0s
does anyone know how to remove the stock shifter in an 07 sentra cvt.
nametakennow
Car: '06 MINI Cooper S
Take apart the center and it's connected in there somewhere.
Try the FSM, it'll have full instructions.
djtorello
Car: 2008 nissan Sentra SE-r
wingedmark wrote:does anyone know how to remove the stock shifter in an 07 sentra cvt.
Pull, its held on with a plastic clip on the front side of the shifter, Bad thing however is most aftermarket shifters wont work with it since its a Rectanguler stalk, not round.
nissantech06
Car: 2007 Nissan Sentra S 2.0
Pull the trim underneath the knob down, remove the horseshoe clip (similar to a crank window clip) and pull the knob up.
wingedmark
thanky you for the info. this should help in possibly finding an aftermarket shifter
nissantech06
wingedmark wrote:thanky you for the info. this should help in possibly finding an aftermarket shifter
It will be hard to find one, the way the shifter is set up, you need one that has a detent for the button AND the overdrive.
