help removing power steering and a/c lines...
fig240SE
Car: 1990 Nissan 240SX SE
i've been trying to get the ps and a/c lines out of my parts car for the past few hours and can't seem to get them off. i've just downloaded the service manual. is there any trick to getting them out or something things are common that i should know?
biglipzit
Car: sr20det S13 RHD 200SX
what is so hard about it? Disconnect the AC lines from the compressor and condenser and unbolt them clips that hold them to the body of the car. For powersteering lines you can take them off the bottle and power steering pump and detach them from the base of the steering Rack. One should be rubber and you can remove the rubber hose from the metal pipe somewhere along it. Just remove all bolts and unscrew all fittings and rip it out.
777aaron
Car: race cars
I know they can be a real biatttcccccchhhhhhh to get off of there.Not trying to be a smart-a$$ but always remermber righty tighty lefty loosey when working on stuff,I still catch myself turning stuff the wrong way every once in a while and I have been working on cars for 15 years.
fig240SE
i got them out pretty easily actually, it was just finding the damn bolt that holds the lines together against the frame, once i got that off, it was cake.
