You didn't start the engine since you lost the piece did you?
The connectors on the right valve cover are for the O2 sensors and other stuff.
The connector to the knock sensor is near there too.
The thermal transmitter and temp sender are at the front, on the water outlet.
Don't break the thin metal terminal when you remove it. Squeeze the connector to release it.
There are two small diameter coolant hoses at the rear of the intake, one almost straight and the other a 90 degree hose.
I just cut them with a steak knife and install new ones. Same with the bigger 90 degree hose at the front of the intake.
You will have to remove the heater hose from the intake metal tube. Just loosen the clamp fully, ( I take the screw and tiny washer off) and CAREFULLY work the hose back off. Spray some silicone under the hose end and try to break it loose. Hopefully you can reuse it, and the clamps too. The factory clamps are the best.
Going back together, make sure all the head and manifold surfaces are CLEAN. I also like to put a thin film of RTV sealant around the water passages on the intake gasket.
Tighten down the manifold as described in the manual.
