elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Thu Nov 03, 2005 6:15 am
Very simple... When you look at the rotor, there is going to be a threaded hole that you can insert a bolt into. What this will do is force the rotor away from the hub.....
attached is a picture of whta im talking about... You will need a 12mm bolt, what I generally do is find another bolt with a 12mm head (somewhere like in the engine bay thats not really important, IE not holding in something vital... IE a trim piece) and stick it in there.....
I dont have the speces of the bolt in front of me, but its going to be any 12mm bolt head that is on the car.....
