DGA »
https://forums.nicoclub.com/dga-u13015.html
Sun Mar 14, 2004 8:57 am
I do it all the time, on all sorts of engines. It will not rotate the engine at all, and will not put any sort of stress on the cam or the chain. The hex cut on the cam, before the first lobe is there so that you could easily align the cam to the sprocket once you are putting the sprocket back on.
