alex61089 »
https://forums.nicoclub.com/alex61089-u127312.html
Fri Sep 25, 2009 5:47 am
This seems like a hard thing to do but it's actually not that hard. You want to pull the colored piece that matches your body of your car. See people usually replace them when the pieces are broken on the inside but your not going to be able to pull the mast if your plastic piece is still inside the gear box attached. Try pushing the mast all the way down then pulling out the unit. From there you want to unscrew the unit and remove the plastic pieces, or piece, when you free these pieces or piece up out of the gears then you should be able to pull out the antenna with no problem. Think of it as trying to pull a dog toy from a dogs mouth, you cant get a hold of it until the dog lets go, or you just yank the hell out of it
