Help removing automatic stick shift knob
staylong
Car: 1995 Nissan Pathfinder
Hi
Posted this in wrong place before.
Anyway I cracked the plastic covering showing the markings telling you what gear you are in. I would like to repair. Also replace the bulb to back light the selection markers. I think the old bulb is inside the housing.
I believe the only way to get at this is to slide it up and off the stick shift. The problem is I am not sure how to take off the knob. Obviously its connected up to the overdrive switch so I dont want to just pull it off without advice.
I would appreciate any advice.
Cheers
Staylong
