*HELP* Remote start install
mohlenbrock1997
Car: 2004 Nissan Altima 3.5L SE package
I have a 2004 Nissan Altima with a 3.5 engine and SE package. I recently installed a remote start and have been having some issues with the install. After tapping into my tach wire (so the remote starter can know if the vehicle has started) I received a service engine soon light with the code P0725 otherwise know as Engine speed signal. After I disconnect the wire I tapped into with and clear the code it does not come back. Then as soon as I reconnect it I get the code again. Is there another wire I could tap into? Am I doing something wrong as far as how i'm tapping into the wire? I have tried the way that the starters company says to do (bulldog security deluxe 500 starter) along with soldering it in and using a scotch lock. At this point I have exhausted my resources and would greatly appreciate any help. :help:
Thanks in advance
Chris
P.S. :newbie:
Q451990
The ECU doesn't like something about what you've done...
If you're sure you have the right wire (confirm it by checking the service manual at http://www.nissanservicemanual.com ) then I would try putting a diode in there. That would allow voltage to flow from the factory wire to your alarm - but prevent any noise or pulses that are coming out of the alarm on that wire from getting back into the circuit. Kind of a 2 way mirror... the alarm sees the signal, but the ECU can't tell that the alarm is there. I'd be surprised if this fixes it - because the alarm should already be engineered in a way that doesn't cause an issue - but it's worth a try.
http://www.radioshack.com/1n4003-micro- ... ml#start=3
The line on the diode would go toward your alarm.
I'm assuming you've contacted Bulldog tech support to see if they have any suggestions? http://www.bulldogsecurity.com/bdnew/re ... eo500.html
Good luck!
Heath
mohlenbrock1997
i did contact tech support and after many different attempts to fix it i am still at a dead end i will try the diode. i thought about it but as you said it would be strange for the remote start to cause this but i thought id see if anyone else had any suggestions thanks for the response ill let you know!!!! thanks again
Chris
mohlenbrock1997
Amazingly enough the diode was working...key word was! I installed a diode and it appeared to be working.then the code came back... it took much longer then before but it is still throwing the code I don't get it im so lost any other suggestions?
Q451990
I would remove the diode from the circuit and test it to see if it failed. If so, I would try a larger diode - but I think the longer running time without the code is a coincidence. I can't imagine anything burning out the diode in a circuit like this...
Is there any other signal the remote start could use?
Heath
