Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Thu Nov 16, 2006 5:43 pm
I also agree. You ought to be able to loosen the bolts on the inside of both the compressor and turbine housings. When you loosen these bolts, you should be able to spin/clock the center section independently from the two housings.
