blkmrkt wrote:yes we got the starter to work by using your "advanced method" in your tutorial but i believe the arm that connects the gear to the motor may be messed up or something. we have tryed 2 starters now and that arm does not connect to the engine and turn it over, the gears in the starter just spin. do you think i am doing something wrong? i doubt two starters arms are both messed up.
Are you sure you connected the battery to where the small wire comes in from ignition. If you connect to wrong spot , only the motor will spin. does the starter spin when you turn the key? Obviously it should to be consistent. yeah, jump start to test battery. If starter is spinning when you turn key and it is right starter, it might be something mechanical as i know zero about that. Make sure you have a good ground.
Modified by vancouverbc at 3:11 AM 1/23/2008
