Im waiting for the leak down and psi kit so I can check the compression next week. I followed the breakin procedure as close as i could... drove it under 45% load thats less than half WOT, for about 100 miles shifting up and down fourth from 50mph to 40 and from third to 50mph then slow down and punch it with like 60% WOT. Then my mechanic suggested just drive it under heavier conditions and basically spank it a bit so the rings will seat over 500miles or so. Valve seal is also suspect because i get no oil burn on acceleration even if i do 80% WOT. if not then its the oil rings, in which case I hate my life.
robomatic12 wrote: Were the turbos replaced during the rebuild? Or if they are the same turbos, did they smoke ever before?
Yea they are rebuilt stock turbos with bigger cold side they arent burning any oil. If its valve seals then its a bit of a relief but will be a PITA of a task.
