float_6969 wrote:That is exactly your problem. No bends, no kinks, and it MUST only travel DOWN. You need to pull the pan, weld up the old drain opening, and put in a new one. The perfect drain line goes STRAIGHT down out of the turbo, and enters the oil pan @ a 45° angle, but ONE 90° bend right when it goes into the pan is OK.
Remember there is NOTHING draining the oil out of the turbo except gravity. If there is any restriction or obstruction of the flow of the oil out of the turbo, it will back up into the turbo, and the seals are NOT designed to have oil sitting against them.
I agree and disagree with this point.
My buddy mark over in the RB forums has a T67 on his RB25DET Neo. We recently put a fresh engine in there and in the process re did his drain line.
Prior, it went straight down but was very close to the manifold. Now, we ran -10 line down to a custom adapter that goes into the block where the drain goes. The new line is almost 24" line and takes a long swooping (but still downward) path to the drain. He has driven the car all the way to orlando and back (over 200 miles) and all around town for a week + now and has had NO issues what so ever.
I firmly believe that as long as the flow is downward some way, and is not obstructed by kinks, upward slopes etc, you should not have any issues.
