mar123 wrote:Is the combination switch the switch on the steering column, any idea how to remove it? Over the last winter the motor would work sometimes and not others and now it won't work at all. Do you know if any of the relays in the fuse panels have anything to do with the rear wiper? I found some of the service manual online and it does seem pretty complicated, involving the BCM and something to do with ground speed affecting the intermittent settings etc.. We had mice build a small nest in the heater fan, I guess it is possible they may have chewed a wire somewhere. In case anyone else has a bad vibration in the fan you can access it but removing the dash, I cleaned out the nest and seeds and it is fine now.
I think it's not as straight forward as most think:
REMOVAL
1. Remove the driver air bag module. Refer to SR-11, "Removal and Installation".
2. Remove the steering wheel. Refer to ST-11, "Removal and Installation".
3. Remove the steering column upper cover and steering column lower cover. Refer to IP-13, "Exploded
View".
4. Disconnect the spiral cable body side harness connectors (A).
NOTE:
Disconnect the spiral cable body side harness connector after
removing the spiral cable.
5. Remove the spiral cable fixing screws.
6. Pull out forward the spiral cable.
In the manual I could not find anywhere stating "check the fuse" so I'm unsure where the fuse is. I don't drive my Rogue in the summer so I cannot check.
