help rear strut bar installation
extreme
Car: 89 nissan 240sx- 92 240sx
i get this bar for my car 89 fastback but the bar don't came with instructions
anybody has picture installed or where this bar install
thanks in advance
Modified by extreme at 6:32 PM 2/1/2007
onosqv
Car: '92 240sx Vert
that's the rear lower tie bar. It goes between the rear toe control arms/rods on your subframe.
To install, just jack the car up, remove the bolts/nuts on the subframe side of the toe control arms, bolt on, and finished.
This should help you visualize it, should make sense once you are under there:
