WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Jul 12, 2013 5:45 am
Hopefully setting up the Decel Air will get everything sorted for you. I haven't messed with a SAFC since 03, so it's been awhile. From memory I set my throttle to 1%, NE1 = 4, NE2 = 5. Then I turned my NE1 down as low as I could go without effecting the idle.
This all has to be done on the first start of the day with the engine cold. The initial Decel Air setting are entered with the key on and the motor off.
This was a KAT with 440cc injectors, but the process should be the same.
