monkeyofdrift wrote:lol when I turn the key all the way to start it, it make the cranking sound but not the vroooom sound lol. but the onlything that is different is just the sound of the fuel pump.
your fuel pump is in the fuel tank--under the trunk (unless you have an external pump).
you could just say: it cranks but does not start. you got me scratching my head for a sec. now tell me this, is the engine cranking at all or the starter buzzing trying to turn the motor? if it's not cranking then: a) check your battery. b) check your alternator --it may be not be supplying power to the engine or not charging the battery and the engine runs solely on the battery until draining it entirely-- your engine might not crank nor start for this reason too.
you said the fuel gauge on the cluster shows 1/2 full, your fuel pump seems to be working, do you have a fuel gauge in the engine bay to verify the pressure. just look around, your fuel system might not be the problem, there could be something else, like loose wires...etc.
Modified by BoostsFed at 3:49 PM 10/28/2005
