Help: Rb20det wont idle
Komatsu X
Car: Silvia
hey my rb20det wont idle .. i did a boost leak test and i had no leaks and i put all new vac lines and i changed the tps & maf and cas and it still wont idle when i let off the gas it dies right away.. about 5 min ago i found out that cylinder number 1 wasnt geting working but pulling all the plugs and only on cylinder 1 nothing changed.. so do you think thats why it wont idle?. after i found out that i change coil packs /coil pack harness /ick pack/ injectors/ and i got new plug and it still wont idle. dose anyone know what it could be????????
thanks
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Komatsu X wrote:hey my rb20det wont idle .. i did a boost leak test and i had no leaks and i put all new vac lines and i changed the tps & maf and cas and it still wont idle when i let off the gas it dies right away.. about 5 min ago i found out that cylinder number 1 wasnt geting working but pulling all the plugs and only on cylinder 1 nothing changed.. so do you think thats why it wont idle?. after i found out that i change coil packs /coil pack harness /ick pack/ injectors/ and i got new plug and it still wont idle. dose anyone know what it could be????????
thanks
Maybe something wrong with your harness? or the ECU is bad?
Komatsu X
Car: Silvia
i changed my ecu and nothing ..still wont idle
