I pulled my rb20det out of my old s*** shell and dropped it in a new one. Everything has been kinda smooth with the transition. The motor ran great prior to the swap and now im running into some issues.
I can start the car with the mafs unplugged it will idle and rev, Then when i plug the mafs in it will idle for about 30 seconds and die if u dont rev, if u do rev it dies instantly. I have all ic pipes on and tight, i did away with the recirc piping. It ran fine until now, i got it to rev with the mafs plugged in for a good 45 secs but as soon as i stopped it died. I have no clue wtf to do now. My r32 cluster is also on the fritz as no guages work at all, and all i did was put it in this shell, worked perfect in my other shell. Im about ready to call it quits. Any help would be appreciated. i will update as i can. Also if u have any questions that might help diagnose the issue let me know and i will answer them to the best of my ability.
