have you tried this before? i'm pretty sure the MAFs are not averaged, because that will effectively cut the air flow in half. if you parallel the maf wires and just run one maf, the ecu will think you are flowing about twice as much air as you really are. there is probably a workaround with the scaling that you can do, but i do not think you can just parallel the wires together. o2 sensors can be paralleled because those are just a binary value.StricNyne wrote:idk if this helps but you can wire the MAFs in Parallel, so it will be like running one maf, well i know that works with a power fc, in which is just literally takes two readings and averages them out, the same with the 02 in the exhaust elbows. I might have a rb26 harness in my garage i will look i know i have a couple series 1 rb25, and 2 converted rb26
