Help ....Ran Out of Gas , Engine Revs but doesn't start .....
keroque
Car: Infiniti G20
Well , my car ran out of gas , so I filled up almost 3 gallons . But when I start the engine cranks but doesn't start ... I can hear the fuel running .... I am guessing the fuel pump gone bad , but I can't find it , how to check it ... any help appreciated.
Thanks in advance !!
bundy26
Car: 2011 Buick Regal turbo
I figure if you can hear the fuel pump then that's not the problem.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Do you have a copy of the Factory service manual? That might help you:
http://www.nicoclub.com/FSM/G20/
keroque
Car: Infiniti G20
I could clearly hear it for first few times , but It didn't start so gave up and tried after an hour ... But Now I cannot hear it .....
bundy26
Then it could be your fuel pump, probably located in the gas tank, under seat maybe.
bakerboard
Car: 2007 Nissan Sentra S 2.0
Sounds like you could of flooded the engine which makes it harder to start. If you don't hear the fuel pump pressurizing then yea could be your fuel pump or something fuel related.
nametakennow
Car: '06 MINI Cooper S
Running out of gas in a fuel injected car is a big no-no. You've probably fried your pump.
keroque
Car: Infiniti G20
The Car is 1991 make Infiniti G20 , so does it have fuel injection system ??
bundy26
Yes it does, I definitely would go for the fuel pump first.
keroque
Car: Infiniti G20
Well , this may sound silly but I am not able to remove the rear seat in order to get to the fuel pump.
how to remove the rear seats , i am following the owners manual but still can't really find the hinges to remove rear seat ...
Any help ??
bundy26
I think there is a bolt on the back of the seat bottom, around the middle.
240sxka-t
Car: 94 sentra ga16 coupe
could have killed the injectors. all the junk that could be at the bottom of your tank going thru the system. damaging and cloging.
GL!
keroque
Car: Infiniti G20
I checked the fuel filter , fuel couldn't reach the filter , so Now I am trying to replace the fuel pump .... the local store says it costs $ 108 ....
keroque
Car: Infiniti G20
Well I didn't replace any of the parts , I left the car untouched for a week , but miraculously the car started working today , but the sad thing is it died after a quick run ...
do you think i should go ahead and replace the fuel pump ??
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
yeth
