help radiator
thepitt
Car: 1990 240sx
i got a question. i kinda new to the 240sx and car world so go easy. i have an automatic 90 240sx. i want to put a new radiator in there because my old one cracked. can i put a MT radiator in there with an automatic tramsmission cooler with it. is there any problems to look for or can it be done at all?
quiksilvia
Car: 95 s14 se
see if the part numbers are the same from nissan.
NISTECH
yes you can put a manual trans radiator in and add an aftermarket trans cooler in front of the radiator (condensor if you have a/c). The bigger cooler would be better for the trans any how.
