Help: R32 Lsd
DriFt3r
Car: Racing and Drifting
I found a really good deal for the pumpkin of the R32 Vlsd. I was wondering if this vlsd will fit my s-14 without the side shafts? I've searched but no one can really give me a clear answer on that.
SmithSR
Car: 240sx
http://www.nissaninfiniticlub....nding
"Another option would be an R32 skyline GTS-T differential which is an RS200. In essence, it is a 1.5 way limited slip differential with a R200 carrier and ring set. it measures about 1" larger than the normal R200."
"The RS200 from an R32 skyline would be just perfect for what you're looking at. It's already LSD, and has 3.96 gears in it so it isn't much of a change from your stock gearing. You'll actually gain MPH in the 1/4 with this rearend. It will cost about $400 and have to be installed by you as very few people in the states know anything about them." --Aries
Email Aries. He probably has the most working knowledge with the R32 diff.
Nismo_Freak
Car: 89 Nissan 240SX
The R32 GTST has a 4.363 final gear, and is a VLSD (not a 1.5 way)
