02pathy »
https://forums.nicoclub.com/02pathy-u44880.html
Tue Mar 02, 2010 6:52 pm
yeah the reason i chose the pathy over the qx4 is because, a body shop manager told me the qx4 headlight was $1500 each and only available at the dealer
nala did what? you should of left it, it would of dried on its own then all you would of have to do is heat it up or apply sealant to it
as for taking out headlight in pathy, i think there are two bolts on the side behind the grill, one bolt behind the filler piece under the headlight, then i think you firmly pull forward, but some else should conform this as this was two years ago
take out the corner light if easy enough and check to see ...
