HELP QUICK... brake lights wont turn off
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
i parked the car, got out, looked at the back to make sure I was in the lines. I got out and walked around back to get my laptop out of the trunk and the brake lights WERE NOT ON. then i go out to my car to get some dinner and i notice the lights are on, i have tried everything behind the brake pedal, by the master cylinder, everything....im at a total loss, i need to figure this out quick, please help.
emperor_lunchbox
i noticed the post below. and even when i push the button in the lights are still on. this is really getting on my nerves, i have nothing but electrical problems with this car. anyone know where i can get a new full interior harness for an s13 hatch.
mss5413
Car: Nissan 240sx
When you said everything behind the brake pedal, did you check the rubber stoppers on the brake pedal arm to make sure there was not a hole there. It won't close the switch if the rubber piece is missing.
emperor_lunchbox
the rubber piece is gone and there is a hole in the arm, im assuming that this is where the stopper goes. I pressed the button while the pedal wasnt depressed and the lights still didnt shut off. This is really getting to be a pain in the a$$. also, does anyone know the part number, if there is one, for the stopper piece. also any suggestions on how to install it. space is pretty tight in that area.
themadscientist
nut & bolt man, works just as well
Neejay
Yeah, a nut and bolt. Been working fine for me for a while now.
I paid like $3 for that small *** OEM plastic piece, and its IMPOSSIBLE to put it back in place. Its very frustrating...
NUT & BOLT!
themadscientist
$3.00!? for that?! you can buy two copies of William Shatner's record for that!
emperor_lunchbox
i got it fixed at reed nissan for $1.60. well actually $11.60 because I gave the dude 10 bux for helping m out. They wanted to charge me labor to install the part and the dude just went outside and popped it in.
