WARFOR2 »
https://forums.nicoclub.com/warfor2-u179870.html
Fri Mar 04, 2011 9:08 pm
for an ls style motor, that site has the cheapest mount kit, with a modified crossmember. That site also has the largest parts list for the ls swap. Certain parts can be done yourself which they will tell you how, but if you aren't the type that can mod or weld or fabricate, these are convienient. Me i'm planning on using his mount kit, header flanges, driveshaft, clutch cylinger kit powersteering lines, and maybe the wiring service. It will make things smoother. I'm going to use a jegs weldup header kit, and a summitracing universal digital gauge set. I know i can make most of the parts myself, but to buy all the tools that i might need, including a welder don't make sence. plus i'm doing my swap on the street once i have everything together lol. i'm not doing anything until i have everything, and the only labor i'm paying for is bodywork, and exhaust/ header welding. The car will be painted for free once the engine is in. having most of the parts premade will make things go faster when doing the swap, then tow to the exhaust shop and drive to the body shop.
