It's really weird. So what you are saying is... it works first 1/3 of the way and stops. Right? Is this pretty consistent? I mean... does it always stop about 1/3 of the way? If so, I don't think it's a switch problem, but next thing you could try is pop out the switch from center console and check for the wire and plug. If you have a friend who has a vert, swap the switch and try. If that doesn't work, you might have to take out quarter window assembly and check for motor/regulator/arm and stuff... ALso make sure the window is on track and guide is not broken. When guide is broken, usually windows go down, but it won't go up easy.dumbusername wrote:Can it be the console button? It doesn't seem to be making contact. Anyway to clean it?
Thought about just popping out the switch panel & rotating it 180 degrees?dumbusername wrote:Also one more funny thing about the quarter window switches in my car. The right switch opens the left window and the left switch opens the right window. Is this just in my car???
That's what I meant... Do it. It should fix it.brokeAs240sx wrote:Thought about just popping out the switch panel & rotating it 180 degrees?
Look carefully. It should be on #7, not #8. That part(#7) has been out of production for a while, so you can't replace it. You have to fabricate it...outdoordiva139 wrote:I have a 92 240sx conv LE and their is a little plastic part I think #8 has been broken in the rear passenger window and the window only goes up 1/3 the way.
