qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Tue Apr 17, 2007 11:15 am
I was referring to the comment by grantfc about the test light activating the relays.
I wouldn't do it that way, I was just curious if he wanted to try it since he was already messing with the test light.
I would just pull the IC relay out and jump the contacts, NOT THE COIL, to simulate the relay being on. If the ECU output isn't working you'd need to do the same thing with the ECCS relay.
In case you aren't sure what I mean by the contacts and not the coil, for the IC relay you'd be jumping the BR/Y and the B/W wires and NOT the W/B and GY/R as that would short out the computer and if it's not already toasted it would be after that.
