Help! Q45 died sudden death but came back to life!
ahukill
Car: Q45
In the past two weeks I have noticed car vibrating when I speed up. When I get to desired to speed, it stops. Yesterday the car would not go past 40 mph and I decided to turn off the main road. When turning, the car died. The car immediately started back up again. It seems when I get to the 40 mph range is when the vibration really starts. I thought at first maybe I needed a tire rotation. Any ideas? I appreicate any help I can get before I take it somewhere.
Signed,Damsel in Distress
Q451990
The vibrations sound like a bad injector(s) but not going past 40MPH doesn't really follow with that. Maybe a bad fuel pump or failing controller?
Heath
96Qowner
Car: 1996 Q45
It's possible you have two problems.
The vibration - is it worst at 25mph and 45 mph? There's a transmission mount that fails and causes a strong shaking vibration at 2250rpm. That's roughly 25mph, 45mph, and 70mph. It's worse when accelerating. May cost $200 or so to fix. If that's the problem, you should also have the exhaust hangers replaced when they do the transmission mount
A bad MAF (Mass Air Flow sensor) connector or failing MAF can cause bucking and jerking and sudden stalling. The connector and/or MAF can easily be cleaned at little cost. Here's a writeup about it:
http://www.q45.org/maf.html
But the first thing you should probably do is have a fuel pressure test done. The Q45 fuel pump doesn't usually last much past 120,000 miles. Listen to the trunk when the car is running. If you hear a loud buzzing sound like a nest of bees, then you need a new fuel pump. That's kinda spendy - $500 or so.
captainluigi
Car: 1996 q45t
Fuel pump more like $250 or less from IOS. Perhaps you were adding labor in.
96Qowner
Car: 1996 Q45
Yeah, I figured Damsel in Distress wouldn't be doing her own work.
I know I know, I'm a sexist.
fixer
Car: 08 Sentra
what year is the Q? Early Qs tend to be real finicky about trans fluid level and can cause stalling when coming to a stop. the vibration sounds like a torque converter proble so i would be checking the tans fluid level first.
ahukill
Car: Q45
Hey....Damsel in Distress is a pretty nice gal! Yes, I am a girl, chick, woman...however you put it. Not insulted!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
no one can help a damsel in distress if we don't kow the model year of her car because itis missing in her profile.
