Zero260 »
https://forums.nicoclub.com/zero260-u34180.html
Sat Jun 23, 2007 1:29 pm
so, I'm hand tightening down the main caps, and the became tight way before the touched the caps, so I thought I'd torque them to see if they tightened down. Well, that didn't work, it still had a gap even when I torqued them to 40lbs. what is going on?(I've got BAD Paint skillz)
and an image of the numbered cap in orientation to the filter houseing
so, what I'm thinking is I put all the caps on backwards, I have the #'s on them facing the oil filter side, is this wrong? if I need to switch them, does that mean the #'s on the rod caps need to face the oppisite side also? I'm confused.
