Help pulling a z32 crank sprocket!!
SlidewayZ32
Car: 1990 Z32 NA
What's up Nico!Of course the noobies have to introduce themselves,so let me do that..Just picked up my first z32 not too long ago,so I'm new to the car and this awesome forum!!It's currently at 214,xxx.Not sure exactly what to do just yet,as in mods/deletes.Any suggestions?? But anyways,let me get to the main point...I've decided to give it a new timing belt/tensioner/cam and crank seals,it seems I can't quite get the crank sprocket removed!I've heard about cutting it,but just curious if there's ANY other way..Everything helps! :wtf2:
z32loverboy
Car: 1990 300zx CRP N/A 5 Speed (wreaked, now a shell) SOLD
1993 Slicktop CRP N/A 5 Speed w/ '90 built N/A motor and interior
1958 Ford f-100 straight-body (Grandaddies truck, resto-project)
Use gratuitous amounts of PB Blaster and soak the sprocket. See if you can get a sprocket puller to get it off. If not the only way is to cut it. but cut it without damaging the crank. Otherwise the crank will have to be resurfaced or replaced. Good luck. Mine's stuck on the engine of mine that blew and I've tried everything from hammers and screwdrivers to crowbars. A lot of times they have to be just cut.
SlidewayZ32
Car: 1990 Z32 NA
Ahhhhh I see..I'll have to try a different puller.Hopefully I won't have to cut...
NolimitZ32
When I did my build I had to cut it almost all the way through and then split it with a punch.
