Help!! Problem with car stalling
Drakelee
Car: 1992 Nissan 240sx RB20det
1986 Mazda RX7:for sale
1997 Ford Ranger:PitTruck<3
On occasion when I push in the clutch my car stalls, i dunno what it is or why this happens, maybe im doing something wrong? any insight?!?
240sx super HICAS
240Runner
Car: 1992 240sx coupe
Maybe you need a new clutch
RedlineDriftCoalition
Car: 92 Nissan 240Sx, 95 Nissan 240Sx, 89 Toyota Supra, 1990 Nissan 300Zx, 1985 Nissan 200Sx, 89 Nissan 2
it cant be the clutch if it was the clutch then it would actually be easier to drive. have you tried checking the wiring from the transmission to the harness the switch can have a similiar affect on the car if its not connected properly. the sensor basically checks to see if the car is in neutral or not and if that sensor is shot then it wont let you start then car.
RR240SX
Reset the TPS per the instructions of the FSM. A leaking brake booster or stuck check valve to the booster will create stalling.
