Help!! Problem with a/c (s14)
lrgfreak47
Car: 240sx
What's up NICO I got a problem while my a/c is running after my car gets running. Turn the a/c on and after a while I get this high squeeking squeeking noice from under the hood and when I'm like move and just at idle the air doesn't run cold only icy when in motion. So what's the deal with this?? I'm in the Cali heat so help me out.
C3Sierra_S2000
Car: 1997 240SX SE LS swapped
Sounds like a loose compressor belt. Check there first.
lrgfreak47
Car: 240sx
Adjusted the pulley and squeeking is elimitated but I still have a problem with it not blowing cold air it does sometimes but it's fluctuates. It will make this tissssssing akin and my Rpms will go up and down. It seems like the car has to be IN motion for air to blow cold could it be the condenser or compresser maybe?? Input greatly apprecaited
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
have you checked the pressures? sounds like a low charge.does it still fluctuate when moving?
lrgfreak47
Car: 240sx
Yeah it does I can kinda feel it while I'm driving
AZ89two4Tsx
Probably the compressor.
Have a professional check it out.
Wc240
97 Nissan 200SX
06 Scion xB
if you are savvy in a/c, you can check the pressures with a Manifold gauge set. By the pressures, you can tell if its a low charge or the compressor. The "tissing" sound, im guessing you mean when you first kick on the a/c? if it is then its definately not the compressor. Shop is gonna rape you on price.
Hell if you cant get it, i have a r134 machine and around your area. ill help a fellow 240 driver for cheap
lrgfreak47
Car: 240sx
Lol for sure Ima try and charge it first and see I'll let you know I'm near laguna
Wc240
97 Nissan 200SX
06 Scion xB
not sure where that is. im outside roseville near antelope
