Help. previous owner runing it without oil.
240sxlvr
Car: 1991 240sx
I bought a 91 240sx ka24de. but the owner said he was running it wihtout oil and one of the cams broke from the sprocket. and i plan on replacing the cam and adjusting the timing chain. What else could be wrong?
silverkaturbo
Car: 91 Nissan 240sx
Running an engine without oil is probably one of the worst things you could do to it. So basically any moving parts that need sufficient lubrication could have gotten some pretty extreme wear; all engine bearings and piston rings come to mind. Also I've heard if your timing is off by to far on these engines you can end up bending valves through contact with the pistons.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
The engine is probably junk at this point.
