Help!! Power To Engine But Nothing Else...?
HeroOr0
Car: 91' 240SX Hatch
Modified by HeroOr0 at 3:04 PM 5/28/2009
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
OMG NO WAI!!!!! did you even attempt to check the fuses first?
HeroOr0
yes actually i did, f***ing smartass, can you even drive stick?
Nacho_240
Car: 1991 240sx LE
I believe it's the 75A alt fuse. It's in your engine bay fuse box and they run $10 on ebay.
HeroOr0
Thanx bro, i'll do a continuity test on that fuse n see what i got....im open for any more suggestions if anyone has em
PhopsonNY
Car: 1989 Nissan 240SX
Check the main cables connecting to your positive battery post...
Some of the cables that bind to that post may have come loose.
Good luck
HeroOr0
Well I pulled the 75A fuse and everything functioned normally, fuse is good. But when I'm driving everything kicks back on but when I shut down it all cuts out even at idle. When I start driving eventually everything comes back on.... wtf mate?
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
bad ground in the body harness somewhere? my first guess was 75a alternator fuse as someone suggested earlier. i would replace it for the sake of it, it controls all that stuff. i did a noobert yesterday while in a rush and luckily it just fried that fuse but NOTHING worked in my car except for the engine. gl sounds like a headache that ive delt with many times.
