help.. power lost
ae_21
Car: 1995 Nissan 240SX SE
well apparently my car isn't running correctly.. i have a 1995 Nissan 240sx se.. ka24de.. i have no power in any gear.. the car runs. but i am not getting the power i had before.. this started happening about a week ago.. the problem that we cannot figure out is that.. when driving there is no power pushing me forward.. the revs are fine. no abnormal idle drop or anything.. what do you guys thing this could be.. also can the cause of the problem be the MAF sensor.. cause that is giving me a code... what do you think the problem is.. anything is greatly appreciate.. thanks in advance.. i would like to have my car running normally as soon as i can.. the car is killing my gas and slowwing me down.. thanks again
ae_21
also .. the power if loss through out the rpm range.. could a clogged cat be the problem too.. thanks again
NISTECH
You need to check your MAF and MAF circuit with a volt meter. The ECM is telling you what system is having a problem so check it out. Do a search here for MAF voltage. Lots of info on it.
ae_21
i sure will check that.. thank you NISTECH
