ImStricken06 wrote:man i wish i could help you....
here is the best advice i can give you: i honestly wouldnt even waste anymore time or money on parts/checking/scanning/scoping/etc. i would just drive this car to and from work and save some money to pay a mechanic to do a full engine swap. crashed rogues are a dime a dozen in junk yards, and you can easily land a new engine with 30,000-75,000 for $500-$800. a mechanic would charge you under $2,000-$2,500 (generally) out the door.
you can pull the head, buy a used head from the junk yard, have it milled down to perfection, buy a new gasket - and find out that wasnt your real problem. now you are out $500 in total.
I appreciate all the help you have given so far. To be honest, I got the car really cheap but I spent a lot of time working on cleaning it up since I got it. I put 1500 miles on it since I resurrected it. I am pissed at myself for assuming the shop that "fixed" the misfire and changed the oil for the previous owner didn't recognize the bigger problem. I guess I should have doubted them when the failed to diagnose a bad battery.
Anyway, people say everything happens for a reason. May this is so that I can learn more about engines.
I digital camera viewed and compression tested the engine yesterday. Being inexperienced at this but watched multiple videos on compression tests, I found that all the cylinders were withing 10 PSI of each other. Cylinders 2-4 had the usually carbon on them when I sent the camera down the spark plug hole; however #1 was covered in oil so much that the camera lights just reflected back (it also had the highest compression.) The new plugs i installed were all okay except #1, of course, because it was covered with oil and it was hardened and flaking off. I swapped it with the best of the old plugs but I suspect this will not last long if I keep driving it.
I suspected that it was the valve seals on cylinder #1 so I added 7 oz. of ATP AT-205 Re-seal to it and drove it for about 80 miles on the Interstate by me. Looped it 3 times in an hour and a half. This only made the situation worse. Kept it below 60 most of the time but then it started to hesitate at 50-55 mph. It was supposed to take 5 hours of operation to treat but I do not believe I can take it any longer without seriously damaging the engine. Oil was brought to level when I started and was not even touching the dipstick when I stopped. Blue smoke during hesitations with some light knocking; however, I have yet to get even a pending engine code from the car. It's like it does not even see the issues!
When I returned I did one more test on the engine before calling it quits. I cranked it up with the hood up and removed the oil cap then put my hand over. It was spitting oil and thumping on my hand. Now, I don't know if this is blow-by from the pistons or it a result of the valve seals damaged as Cylinder #1 is right near the opening. The answer to that would be most helpful.
Anyway, I am going to proceed with replacing the valve seals on the entire engine. Since I am going in and they are only about $3.50 a piece, I will change them all. If anyone has photos or videos on how to remove the valve cover and the camshafts without removing the timing chain, it would be appreciated. The camshaft removal looks possible if a dowel of some kind is used in place of the camshaft while it is out. Also, if you remove only one shaft at a time and work just that side then switch, it also seems like it could be done.
If my theory on this is off (or way off), please let me know. I'm sure my inexperience with these things is showing but I am trying to stay optimistic about this. Thanks again for everyone's help. Keep it comin'!
