Checked distributor, cables, connections and plugs.ARKQX33V6 wrote:Verify your distributor with P0300 miss fires, check HT cables, connections, plugs
How would i verify advance is working?ARKQX33V6 wrote:You may be in limp home mode also because of timing belt change do a static timing check and dynamic verification and see if advance is working.
