Help! popping and loss of power
Mychal
Car: 89' Nissan 240sx
So just the other day i got on my 240 a little and noticed it felt like it had a lose of power at higher rpms and stops pulling strong and starts popping and crackling..just driving around it drives fine...Ive noticed the fuel pump seems to be really louder and when i go to pump gas when i open my cap air comes out where the cap isnt venting i guess..idk if that has anything to do with it but just thought i would mention it... and a few times when i turn my car off its like it wants to keep running and the motor shakes bad and makes like a "psssh" sound or like a air pushing sound.. doesnt sound good at all... but the car drives fine.. idk what it is!??...ive checked the vacuums and the piping and everything looks good
any help would be greatly appreciated
stock sr20det btw
stock piping and side mount
Mychal
any help??
krash
First, I thought your title said "Pooping and loss of power."
Second, if your gas cap hisses at you when you open it, that means you bought a Nissan 240sx.
As far as the crackling, popping, and loss of power: I don't know much about SR's, but that just sounds like the end of the powerband. What RPM does this tend to happen?
Mychal
im not sure my oem tach isnt hooked up...id say not redlining so prob 4 or 5ish
nismoracingsx
Car: 1993 White 240sx Coupe
lol, you're running it that high w/o a tach?
....did you replace your stock 240sx fuel pump when you swapped in that sr20?
sounds like your strained pump is dying..
benarovi561
Car: 92 black hatch
Mychal wrote:any help??
well it could be a number of things. First, get the tach working. then u can tell what rpms it is loosing power at. Make shure your fuel pump isnt stock one. It could be your loosing power at a certain rpm because of cam timing, even a bad maf. Go buy maf cleaner(dont spray anything else into the maf it will f*** it up) and clean it, see what happens. Then let us know whats good.
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
check your coil packs.
Mychal
i fixed this awhile back
havent been on nico in awhile
it was the filter on the end of the fuel pump....its was dirty...it look like rust (muddy lookin)
