DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Thu May 28, 2015 9:50 pm
^^I think he said he had a 34, knock sensor.
I had this problem once way back with the NA, and be damned if I can't remember the solution. It may have been my one hardpipe that had a split in it at one of the vacuum bungs I finally replaced, and also could have been when I did a FPR and fuel dampener change. The dampener is affected by heat as I remember and important at under running conditions to keep the fuel supply steady, so check those two just for "why not" purposes.
Also as NoLimit said the vacuum hunt is not easily done by spraying or otherwise, but by replacing hoses and checking the units on either end for correct operation. The IACV can give some odd operation under hot conditions, and corroded connectors is a constant issue and can be involved if not the cause of a myriad of issues...check them all for green corrosion and clean/replace as necessary, ESPECIALLY if the connector is broken.
Hope this helps!
