pnw240 wrote:k, well and the other thing is, there's no sound from the engine bay at all when i turn the key, like it's not even trying to start
how is your alternator? are your lights brighter when engine is off?
Alternator test using volt meter:1.turn headlights on for 15-20 seconds to remove surface charge2.measure voltage across battery when engine off3.turn off all electrical loads ie wiper ,etc4.start engine and increase speed to 1500 rpm5.measure voltage across battery with engine steady at 1500 rpmthe voltage reading should be at least .5 volt higher with engine running. if voltage goes up more than 2.5 volts, alternator overcharging.
You can also test with engine running with lights on at 2000 rpm. the voltage should increase at least .5 volts
