nissan240boy »
https://forums.nicoclub.com/nissan240boy-u182547.html
Wed Apr 04, 2012 1:46 am
ok i have a ka24det and im running 9lbs of boost and she runs great and spools very quickly and im running a $200 ebay turbo, fyi if u plug ur waste gate and u got no increase in boost either ur turbo is junk and not spinning fast enough or you have a major boost leak, also a major boost leak will make that turbo spin insanely fast to make up for the lost air till it opens the waste gate and ull ruin the turbo with a major leak over time. My turbo builds 9 lbs in about a second if I smack the throttle to the floor at 4,000 rpm, also kat's make there power between 3500 and 6000 rpm. You should never try to stop the blade of a turbo while its spinning one so you dont loose a finger and two so you dont cause the nut to come loose on the compressor wheel, when you accelerate and slightly get on the gas, can you hear your turbo spooling or do you have to really get on the gas to build boost and to spool the turbo, check your turbo exhaust gaskets, if the gasket between the manifold and turbo or thr downpipe and turbo has a leak youll have major boost lag, your exhaust must be sealed 100 percent to the downpipe, also im pretty sure on this and guys feel free to tell me if i am but you set your timing to stock, you dont advance or retard it, thats what the ecu is for it will adjust the timing acordingly if the ecu is tuned correctly for the setup cause having the timing too far advanced or retarded will destroy a turboed engine, hope I helped you some
