Help Please! Won't Start!
schassisonly
Car: 1995 S14 LE (CA)
I only started to notice this afternoon when I got off work. I went into my car to try starting the car, and it wouldn't crank. I then proceeded to try again, and it would fire up. Struggling to, but eventually did.
I then drove home, and parked it. Just now as I went out to turn it on, it wouldn't turn on. It clicks once, and all the interior lights, dash symbols, etc, shut off. When I reconnect the battery, the interior light will come on full power. Dash lights light up on ACC. But when I try to crank, it clicks once, doesn't crank, and all interior lights including dash symbols shut off again. If I reconnect the battery again, the same thing happens. Interior lights come on, dash lights on ACC, then when I try to start it, it will click, and lights shut off, etc.
Its not the battery as I've tried two brand new ones. I do not think it's the alternator either. I have not push-started the car yet to see if it's the starter, but I suspect it is.
What else could it be?
EDIT: I've repeated the battery reconnection process a few times, and around the 2nd or 3rd try, I heard a rapid "clicking" sound from my .... dash? It sounded like the driver side somewhere. It was a lot of clicks in a few seconds. Sounded like a semi-automatic rifle unloading a clip, except it was unloading "Clicks"
Thanks.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
If you jiggle the key, or change the position of it and go back, does it help? Almost sounds like you're ignition switch or ign relay might be out.
