Help Please with Fuel injectors
soynissan
Car: 1990 Nissan 300zx TT
Hello everyone, i am in need of expert advice I own a 1990 300zx TT. I am currently rebulding my trubos and changing all hoses on my engine. I recently found out that one of my injectors isn't working and rather replacing only that one i would like to buy all 6. The problem is i dont know how many cc my injectors have right now and if i can go with bigger injectors without modyfing my computer. Thanks
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
If you do buy bigger injectors, you will need to upgrade your ECU. Are you rebuilding your stock turbos, or are you getting bigger turbos? If you are just running stock turbos, stock injectors are just fine.
soynissan
I am only rebuilding my stock turbos. Do you know how many cc's do my current injectors have? WHat would happen if i go bigge without upgrading ECU?
freakonaleash1187
I believe the stock injector size on TT's are 340CC. Your ECU is programmed to only run on one size of injectors, and that is 340CC, so if you put bigger injectors in there, the ECU will flood the engine with fuel.
soynissan
oh crap i see thanks a lot! Better stick to the stock ones
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Stock TT injectors are 370cc's not 340cc's
freakonaleash1187
^^^ Thanks for the correction, I wasn't exactly sure, but I knew it was in the 300's.
soynissan
Now im trying to buy the injectors, they told me that Stock ECU will handle up to 440cc injectors with a little rought idle but its possible for better perfomance is this true?
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
Who are "they"? Because....they are dumb.
soynissan
They are a venom fuel injector dealer. What would happen if i get the 440 cc injectors? Is there any truth to what they said?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the result of just putting 440cc injectors in is that you're pouring 20% more fuel in all across the board form idle to redline, this means you run rich and burn more gas while making less than optimal power, it isn't too expensive to get the remapped ecu to wrok with the larger injectors but just plugging in larger injectors won't make more power
Srowlands
Car: 1990 300zx TT
I put 440cc venom injectors in my 1990 300zx TT and it runs very rich at idle. I have to get my ecu retuned to idle better. A JWT tech told me they are having a lot of problems with Venom injectors and he had me send mine in to get pressure tested. Hopefully the results are good and I won't have to fight to get my injectors returned. I should have bought 555 cc ones but I didn't think I would upgrade my turbos.
Anyways the Venom dealer also told me that I would be able to run the 440cc injectors without upgrading the ecu. Well he was wrong, it runs to rich at idle.
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
Honestly, don't buy injectors from Venom or trust what they tell you.
freakonaleash1187
^^^ Agreed. From what I heard, Venom isn't really that great of a company to work with. Get some NISMO 555CC injectors with a remapped ECU and you will be set, or stock injectors if you want so you don't have to remap your ECU.
soynissan
Thanks everyone
soynissan
Srowlands wrote:I put 440cc venom injectors in my 1990 300zx TT and it runs very rich at idle. I have to get my ecu retuned to idle better. A JWT tech told me they are having a lot of problems with Venom injectors and he had me send mine in to get pressure tested. Hopefully the results are good and I won't have to fight to get my injectors returned. I should have bought 555 cc ones but I didn't think I would upgrade my turbos.
Does it idle too rough?
