help please w/wiring im new to the site
blacktopsr20
Car: 95 240sx
Hi everyone Im actually not new; I just had a time to register for the site.Im not sure if this is the right section where I can ask these kinda ?s.Ok, I got a 95 240sx auto. I just converted to manual and put a sr20 black top in it the one with the hump on the top. So, I wired everything on it. except that blue plug beside the ecu. I tried to crank it up but it won't start Im getting fuel but no sparks. Im thinking that blue plug has something to do with it. Also there's a litte white plugs beside the interor dash plug I don't know where it goes. This is my first sr swap, so any help guys will be nice.http://i232.photobucket.com/al...6.jpgh ... al...4.jpg
Hijacker
Car: '92 240sx Convertible
'94 F-150
The blue plug is your ignition coil relay plug. It should have a Black/White wire, a Black/red wire, a Black wire, and a Blue wire going into it. From the pic, I can see a Blue and a Black/Red, so its safe to assume it's the correct relay.
The other two relays are fuel pump and mirror defogger. Something tells me you don't have mirror defoggers, so you can switch the relay over to the ignition circuit. The defogger relay is the one with the two Green wires, Orange wire, and Blue/Yellow
blacktopsr20
Car: 95 240sx
thanks for the reply man. I done that b4. I switched the relay but still no spark. I don't get any check engine light when I turn the ignition on. I don't know if my ecy is bad or not because it rained on it but I blow all the water out of it.
