r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Wed Dec 29, 2004 8:54 am
ill run a compression test, but i checked and the timing is pretty much dead-on. the engine was also just rebuilt.
the injectors are not new or refurbished but they are all working as they should (checked them myself).
the car ran fine before i rebuilt the engine, so i dont see what the problem is now, as the only thing i added electronics wise is the z32 maf (though i do agree with rafi, dont add these things until the car runs. itll save some real pain).
the car does NOT backfire. i tried unhooking the safc but got no change.
redamnavit: its just like that one, but the pin is just connected directly to the board, it isnt socketed. ive got the injectors (somewhere) and i can try those if need be... though the safc is set correctly. there should be no problem there but whatever, ill try anything right now.
the part we dont understand is that the car ran and drove for 3 days, then it just wouldnt start one morning and hasnt since. the only problem we were having was that at the time i had the maf wired wrong and the safc wasnt set up quite right. now its all sorted out and it wont start. its very ghey.
on the bright side of things, i got my vlsd in the mail today! its gonna be schweet. got the z32 unit for those slightly lower gears, since i do a decent amount of highway driving and i want my engine to not die from over-revving at 80mph (stupid 4.08 rear end making me do 4k rpm at 79mph). now the car should top out around 175mph, and i intend to check it as soon as i get my cage put in.
thanks for the help guys, keep it coming! i will find the problem, mark my words!
- tim
